1 - 20 of 217 Posts
Thought I'd have a see what all the fuss is about. Will report findings when fitted
Sent from my SM-G930F using Tapatalk
Anxious! I'll be ordering one soon as well. Post up.
Tagging this. I too am extremely interested in what this unit has to offer. What exhaust will you be pairing it with?
I have already fitted an Arrow system and dumped the fat cat and servo.
Discussion Starter · #6 ·
I have ordered a K&N filter as well
Discussion Starter · #7 ·
Ok . It's arrived.
Discussion Starter · #9 ·
Going to be fitting the K&N then this today
Although the instructions don't say it, I believe you do need to lift the tank out of the way to get to a few connectors. In your case that won't be an issue as you would have to remove the tank to do the air filter install. Do post photos of the installation, I'm curious to see where the unit sits exactly.
Discussion Starter · #12 ·
I was going to get an MWR filter but as K&N are in the UK decided to get one.
Discussion Starter · #13 ·
Ok the K&N is fitted. Looks like the dealer just lifted up the tank and rammed the original filter in there looking at the state of it. I can't believe how much of this fucking bike you have to strip to get anything done. It's worse than the SF.
Discussion Starter · #14 ·
Original and K&N
K&N is a nice snug fit. Very tight so I can't imagine any side leaks
Discussion Starter · #15 ·
The plugs I have piggy backed onto the originals so it's neat
Discussion Starter · #16 ·
Discussion Starter · #17 ·
I have run the loom around. I have tried to put the box everywhere in a better place but there is just no room for it. Ended up undoing the bracket on the top cylinder to get enough cable to fit it where it says near the front. Only other option is under the passenger seat by notching out a groove to fit the cable. It may still end up there
Discussion Starter · #18 ·
Ok so after temp fitting the tank and panels they want you to fit it on top of the radiator Velcro,d to the rad cap. Fuck that it doesn't sit well with me. Plan B in operation
Discussion Starter · #19 ·
It's not right there at all is it ?
No, that doesn't look like a good location to me either. Can it go verticle right there above the starboard ignition coils behind the faring side panel frame?
1 - 20 of 217 Posts
