1 - 14 of 14 Posts
Hey all,
I'm looking for a phone mount for my 1998 ST2. There really isn't any room on the heli
bars. Anybody have any suggestions? TIA
Luke
Same setup for me. Replace one of the mounting bolts with the ram ball and then use one of the short extenders to position the grip wherever you want. I actually like this setup better than just the standard handlebar clamp version I use on my multi.
https://www.rammount.com/part/RAM-B-367-UN10U
Sent from my Pixel 3 XL using Tapatalk
I think Desmotimes used to sell an adaptor for the triple tree nut that centered the ram between the bars.
On my 2000 ST2, I used a Ram X-Grip and short ball to ball arm connected to a ball mount bolted under the plastic tank cover/key guard using the ignition key mounting bolts. Had to grind a little off the ball mount. Its hard to tell from this pic, but the ball sits just outside and forward of the tank cover with plenty of clearance for the ball-to-ball arm to mount. It put my phone well back from the instrument cluster which didn't block any views. Worked very well.
r-
Tom C.
1 - 14 of 14 Posts
