I'm excited to try this out, I'll post my settings here as I progress.
The last day of the riding season last year, on my first full throttle run of the afternoon, the bike went into limp mode. I put it in storage until last month, and set the dealership on it. Of course they blamed the RBEvo, which I had put a bypass module on just to be safe. The tech wasn't familiar with RapidBike (which should have been my first warning) said he "saw the same thing with a KTM," and so I had to remove all the RB harness (I actually left it, just swapped all the plugs back and removed the TPS splice.) I immediately activated the CEL with a full throttle twist, even when parked. When riding, at the first full throttle, the CEL came on, and the throttle went full digital - like no analog feel, basically 0-10-20-50%. I rode it back to the dealer feathering the clutch like a two-stroke. I took it home, and pulled the twist grip cable and tested the pots/outputs from the twistgrip and found no change to the wiper outputs, even when actuating the throttle. I also found an open circuit to the redundant pot. I highlighted the schematics, included my measurements, and dropped the bike off again with instructions to change the twist grip.
Bike is an '18 939SP with 4600 miles.
