1 - 16 of 16 Posts
Hello all,
I’m considering a radiator guard for my 13 Multi, (PP if it matters)
If you have installed one, would you recommend it?
I’ll assume that this type of add on has been properly engineered for air flow and function. Meaning strength and open area of space, and ease of installation.
If you have any that you can give a thumbs up too, that would be much appreciated.
Thanks
Discussion Starter · #7 ·
Thanks for the great leads.
One of my concerns was aluminum vs stainless steel.
Those of you that have the aluminum gaurd, non-issue I assume with a softer metal, correct?
Watching for other opinions. It's a screen, so I imagine so long as it's not made of braided gum wrappers, it'll provide some addtional protection. I had a Cox on my Daytona 675. Right now I'm considering the Evotech and the RG.
Discussion Starter · #10 ·
Redbrit,
Would say that the Cox guard is lighter that you would have liked it to be?
Redbrit,
No, I felt it was plenty substantial. It seems to me that the effectiveness of these guards depends on the size of the openings, the gap between the grid and the radiator fins (giving room for deflection after any impact), and to maybe a lesser degree the rigidity of the material. I'm not an engineer, but that's my thinking. The MTS radiator is a little higher and maybe a little more exposed than the Daytona, but also a little narrower in both dimensions. To some degree it may be a matter of getting something on there.
HTH.
Nonissue... maybe aluminum would be a concern if you're going to be blasting down singletrack and are worried about a tree branch taking out your radiator, but that's probably not a problem for most of us. :)
Our guards are design out of aluminum both the expanded metal and the frame, cut from a sheet, no welding.
1st Aluminum doesn't retain any heat and changes temperature with coolers.
2nd the expanded metal has a grain that maximizes protection and maximizes air flow. Laser cut sheet do not.
We anodize all ours guards to again optimize air flow, and temperature change, for a tough chip free finish.
Thank you for your considerations.
hope im not being to forward..
Andrew
North Carolina, USA
Had Cox radiator and oil cooler guards on my '10. Pulled them off and put them on my '12 when I traded bikes. Rad guard has a few dings after about 40k total miles, but no damages to either of the bike's radiators.
1 - 16 of 16 Posts
