Hi all,
I was planning to flush the radiator and put some fresh stuff but after I saw some instruction on how to I am changing my mind, especially just to remove the radiator cap you have to remove half the bike's top.
So hear is my thought. What if I open the drain plug and remove the reservoir cap and let it drain. Then close the drain plug and refill from the reservoir run the engine to cerculate and keep adding coolant via the reservoir until it levels out, would that do it?
Thoughts?
ah shucks, I thought I had it licked!
It'll be near impossible to bleed, especially since you have two radiators. You really only need to remove the right side intake scoop a few other odds and ends to get to the radiator cap. From there it's pretty easy to fill if you use a funnel and piece of tubing.
It never occurred to me the bike has two separate radiators as if I'm blind. Thanks
