The previous owner put a termi pipe 3/4 system on my 749s and took out the race ecu claiming it did nothing HP wise...well i noticed the bike had a hiccup so i put the ECU back in which solved this, while installing the ecu i noticed how rediculously annoying it was to remove the heat shield to the back of the battery box without pulling on any of the connecting wires too much, i accidently bent the heat shield a bit while doing it.... is there a better way to go about getting behind the battery box,are the cable disconnects deeper within the ducati ?
thanks for your time..
cheers,
alex
cheers,
alex
