1 - 2 of 2 Posts
RaceTech Rear Showa Shock Spring: Ducati 848, 1098, 1198, Streetfighter
$117.95
Racetech rear spring with adaptor ring for install on any Showa rear shock for a 848, 1098, 1198, or Streetfighter.
Stock rate is 8.7kg (sprung for a 250 lb rider), we offer the spring in 8.0kg or 8.5kg to suit typical rider weights, check our application chart on our website for your specific weight.
Discussion Starter #2
Custom MotoWheels by Race Tech Shock: 848-1198
$429.95
This is the shock you get when MotoWheels takes RaceTechs entire product line and throws it at a very capable OEM Showa shock (this shock has adjustable rebound and compression just like the Ohlins DU515!)
Brand New Oil and Dust Seals
New Reservoir Bladder
High Volume RaceTech Reservoir Cap
Race Tech Gold Valve Kit
Custom Sprung for Rider Weight
RaceTech Super Slick Fluids with 200 PSI Nitrogen Charge
1 - 2 of 2 Posts
