The best mod you can make to your hyper!
If you had to choose between an S or a Std - Choose the std and buy the racetech cartridges to go in the forks.
I just had these installed and have taken them for a blat. words can not describe the difference in the front end. (and rear with a valve replacement and rebound seperator valve)
there is no harshness, only firmness. the levels of grip coming from the front end are simply astonishing. I am now having issues of actually turning too much.
The rear is also vastly improved and does not go harsh over the bumps, way way better than the stock ohlins now.
This is how the bike should have come stock. you can plant the front wheel (and I mean plant) it into a corner and it seems to just pull the front end round better than i ever expected. I used to chew up the rear tyre like mad just trying to keep the bike in control, now the rear looks great and I'm riding faster..
If you think that $1200 is a big investment, its not really. for $300 you can take superbike spec forks to your next bike as they are interchangeable so consider them an investment.
so rating for this mod 11/10
