Wanting to get rid of that mass of plastic on the back of the Streetfighter, as I have done on just about every other motorcycle I've owned, I jumped on the R&G Racing Tail Tidy when it became available. It arrived yesterday and I put it on this morning. Here are some pictures of my completed install as well as a few notes about the product and the installation process.
Here you will notice that the holes in the Carbon Frame and license plate are not used. That is because the base of the tail tidy that the plate mounts to has a max distance of 5 inches between holes for plate screws. My tag, which is pretty much the same as most states I think, is 6 inches between the mounting holes
. So I had to drill new holes closer together in my tag to get it to mount to the plate. R&G is a European company but in order to market this product in the U.S., they need to make it work with U.S. sized plates.
http://www.ducati.ms/forums/attachment.php?attachmentid=50577&d=1246473336
A side angled view of the tidy.
http://www.ducati.ms/forums/attachment.php?attachmentid=50578&d=1246473336
Here is a shot of the underside of the tidy. I will say that it is a major pain to get all the wires tucked into the cover on the tidy. There is a mile of extra length stuffed into the stock piece that must be folded and crammed up into the provided cover. I see from my picture that I've got to re-route the R blinker wire because it is pinched in the cover
. The bolts that mount the cover are very short so you have to cram, hold, screw all in one motion which is difficult. If the screws were a little longer, you could possibly start to thread them to hold the cover up, then position the wires and then tighten. But there isn't enough length to do it. It can be done, as you can see, but having an extra hand to screw as the other hands position wires would be helpful
http://www.ducati.ms/forums/attachment.php?attachmentid=50579&d=1246473336
When it is all done, it really does a nice job of cleaning up the back of the bike.
http://www.ducati.ms/forums/attachment.php?attachmentid=50581&d=1246473336
From the side, it really looks nice.
http://www.ducati.ms/forums/attachment.php?attachmentid=50580&d=1246473336
Changes I'd like to see in the design relate mostly to making it a U.S. spec piece. Spread the license mounting plate out to accommodate our plates first. Then I'd like to see the signals mount further in towards the center. I don't care for them to be too close, but the stalk could be covered up some by the plate and I'd like it better, and it would conceal any wire still showing from behind. And, allow a little more room in the cover underneath for the wires, with slightly longer bolts. I wouldn't want to have the cover too big as that would make it look awkward but it really does need a little more space.
