1 - 10 of 10 Posts
Hey everyone,
I'm upset right now because I bought a used Ducati 2001 748SS and just noticed it was leaking oil. It only has about 5k miles on it so I didn't thinkg it would have any problems with it.
Dropped it off at a Ducati dealer in Metuchen, NJ and they are quoting me about $1,200 to open up the engine and check out the 2 supposed leaks they found when they cleaned the engine and took it for a ride.
This is a lot and just wanted to see if anyone has any recommendations. Anybody know anybody cheaper that can do a good job in the tri-state area? Thats a lot of money to spend and I don't trust myself to do that job on my own.
Thanks
748 leak
i guess that's a quote is to check out the leak(s), then give you a quote on the repair?
many shops get $100/hr, so that's 12hrs to take off the bodywork, disass all fuel/wiring/incidentals, dis-ass the engine, then re-ass everything. the labor rate is market-driven, and the time actually sounds kinda reasonable.
to source the leak i'd get a second opinion from another shop, and maybe here. any pics?
Whether it's fair or not depends on where the leak is. If the repair involves splitting the cases then it sounds ok. If it's a valve cover then it's way out of line.
There's probably a good chance it's coming from either the head bolts/studs being broken or loose, or another common place would be a cylinder gasket. Whatever they need to do, you can be pretty sure it'll be an engine-out procedure, with $10 in parts and $1,190 labor. Is there any part you're able to do yourself for dismantling the thing? I just took the engine out of my supersport, not bad, and took around 3 hrs? IF you could give them just the engine, I'm pretty sure the price would be more around $300-$400 by saving them around 6 hrs in 'dis-assing' as standswithabeer said.
+1 on that, the engine can come out with most of the bike still intact, maybe 3 hours of your own time if experienced.
Discussion Starter · #7 ·
Yes it is a quote to split the engine and with repair its going to be around $15-1600 now. I guess it is reasonable considering the work that can be done.
Wish I would have thought about removing the engine myself and giving them that. I guess my biggest concern is I bought the bike for only about twice as much as its costing me to repair it. Guess thats why I got it so cheap haha.
Sad part is I graduated with a Mech Eng degree but still don't trust myself to repair it since I better there are a lot of technical aspects that only specialists know i think.
they found 'supposed' leaks...
does this mean you did not take the bike in to get the leaks fixed?
before spending 1500bucks, i would be taking a very, very close look at those leaks.
i can spit further than i trust the nearest duc dealer around here.
How bad is the leak and what harm will it do if you leave it leaking?
My ST2 developed a leak a while back. I decided it wasn't worth fixing for now, so.....I've put about 20k miles on it and the leak is about the same as it was. I just don't worry about the engine looking filthy. In the situation of splitting the cases, I have always figured if I'm splitting the cases for anything, it'll be for a total rebuild and not to just replace a $3 seal.
+1 absolutely. Splitting the cases means it wasn't any head gasket, broken stud, or bad pistons/rings. If it comes down to splitting the cases, I think $1,500 sounds like a normal price on your machine. I don't think you'll get a much better price elsewhere at a reputable shop.
With that said, if you still have the bike in your garage, I would get in touch with some local Ducati owners. Give them a couple beers to come look at your bike and offer some free advice/help with the issue. If you're like me, $1,500 is a lot of money. I think a lot of board members are like me where we wouldn't have any problem being invited over to someones house to give them a little help with their bike. Heck if I was close by, I'd help you drop the engine for 3hrs on a Sunday afternoon if you gave me like $50. You're 2,000 miles away from me. Look in the 'Regional Discussions' area of the board for people near you? GL.
1 - 10 of 10 Posts
