Quick Release Metal Fuel Connector Kit
Price: $89.95 /set of 4
Theses fitting are made from chrome-plated brass by CPC. Replace the fragile OEM male/female plastic fuel connector with strong, fail proof metal one with viton O rings.
The OEM unit is very fragile and brakes off easily under heat and pressure and can cause a breakdown while on the road. The original unit may also cause a fire, resulting in a total loss of the vehicle.
Connectors are sold each or as a set of 4 (most applications require 2 female and 2 male)
Note: This connector is not compatible with the OEM plastic connector, for use with the metal male/female Q/R fuel connector only
* Outside continental USA, use shipping coupon codes
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
