1 - 9 of 9 Posts
Does anyone know which hose is which for the fuel pump.
As in the 2 lines return and pressure from the fuel injectors.
I freakin forgot which was which. 98 st2. Thanx....I know
what a dumbass!!
I just need to know which side of the fuel injection rail
they go too. My lines don't have return or pressure on them.
So if someone could look at their bike and tell me where the
out hose goes and the in hose goes that will really help me.
thanx
I love DUCATI.MS
thank you jerry...you rock!!!
I switched the lines and blam
she fired right up. I havent been this
happy since last fall. figures that it
snowed here today, but it's nice to hear
that bitch rumble again.
thanx again!!!
Jake,
When I look at my service manual ('03 ST4S), it looks like it does not matter which line you connect the IN and OUT to. The FI lines are pressurized by the fuel pump. If and when the pressure goes above a certain level, the extra fuel is returned back to the tank. It appears that both IN line and OUT line plus the two injector heads are all connected to the same loop.
Did the FI not work when you had the two lines connected differently and then started working when you swapped the lines?
-Fariborz
Chilehead
That's correct, it doesnt matter which way they are connected on the STx, as the regulator is in the tank (I think that mine are currently swapped, as they fit better that way).
Tom
Discussion Starter · #8 ·
yeah, they only worked when they were connected properly...go figure
1 - 9 of 9 Posts
