1 - 2 of 2 Posts
I've searched, but found no answers. I need to know what size the pistons are on the levers of an '03 999. I am trying to order replacement levers, but some brands are piston size specific. I assume the brake and clutch levers will be the same size.
I found information telling me where to find the stamped number, but haven't had any luck there, either.
"front master cylinder - check the top or bottom of the lever clevis for a stamped alphanumeric string. The last two digits in the string indicate the piston size in mm (example: '1PJK 15' = 15mm piston)"
I was unable to find a string of numbers as described.
Any help?
1 - 2 of 2 Posts
