1 - 7 of 7 Posts
Temporary greeter
It looks like you got it excited.
Did you rub it? :D
I'm seeing your clutch switch. Am I missing something? :think:
:D
Switch? I'm not sure I understand. Isn't it a hydraulic clutch? Sorry if sounds dumb, but I'm used to cable actuated clutches. This particular one sort of new for me...
Temporary greeter
I don't know what bike you have but it tells the rest of your bike whether you pulled the clutch in while it is in gear so you don't start it, etc.
Hope that helps.
Hope that helps.
What he's trying to say is that it prevents the bike from starting in gear unless the clutch is pulled in...;)
Super Moderator
Keep an eye on that switch...they have a tendency to separate at the seam (you can see one of the two little tabs on the switch in your photo). If you don't catch it in time you can lose some internals...a new switch will set you back about $70.00.
1 - 7 of 7 Posts
