1 - 12 of 12 Posts
Those should be perfectly fine. Many people make a big deal over being picky about silly things.
Synthetic oils are better than natural. If you have a wet clutch, you need an oil that is designed for that, which your link seems to be. With a dry clutch, even that doesn't matter.
I've been putting into my Ducati whatever synthetic is easiest to get at any given moment, and changing it every 5K to 6K miles. I use the recommended 20W/50 for most of the riding season, but sometimes switch to 10W/40 for the colder months, when it's usually below 40F out. That seems to have worked fine for the last 260K miles, so I'm calling that good.
PhilB
Just Visiting Your Planet
Some K&N 153 filters don't fit anymore. They redesigned the depth of where the threads begin and some won't grab the nipple to screw on. I've switched to Hiflo Filtro. Not sure if K&N went back to the previous design. Caveat emptor.
PhilB
Cheers mate.
I live in the UK so it's always the colder months. Haha. :wink2:
K&N suggest this specific filter for my bike, so if there's a problem with fitment they'll have some explaining to do. :wink2:
Cheers mate.
lol. I don't know how cold it is where you are, but in metric terms I run 20W/50 when the temps are generally going to be above 5C, and 10W/40 in months when the ambient temperatures are typically between 5C and -7C. I don't think it's *always* that cold in the UK, but I may be mistaken. :)
PhilB
Discussion Starter #7
PhilB
Haha. We actually had some sun yesterday. :wink2:
Cheers mate.
I'd suggest you read your owners manual, and use the oil best suited to your climate.
Since you don't list your location, how can anyone give advice on the best oil for you?
Craig
Discussion Starter #9
Craig
I suggest you actually read my original post, and write a reply that's best suited.
I wasn't asking for suggestions of what oil to use, I was asking if anyone had used the oil I'm intending to use and what they thought.
Thanks for being the first instance of negativity I've encountered on this otherwise great forum.
Nothing negative in my post, only truth. I did read your post and have never heard of puta line, but I hear it is a swear word for Spaniards . Puta :grin2:
Use whatever oil you like puta.
How come your suing them for using their brake fluid?
Craig >:)
I've heard good things about this putoline Nano oil.
On dutch fora they 're pretty positiv on this oil, but not specificially for ducati's. Read that they use it in speedway also.
I myself considered using this putoline nano oil but then in spec 15W50, I think that's better suited for your ducati.
But I decided to go for Motul 300V so that will be used in my tuned 888SP3.
Was this ever figured out?
There's a crazy combination of reviews swearing blind that they don't fit, and others saying they're still fine.
I've gone to the stock Ducati filter for double the cost for the time being.
1 - 12 of 12 Posts
