Well at least the 999 has a needle bearing and a seal on the pushrod...And in that clutch world there are no needle bearings or seals.
http://www.desmoduck.com/view.php?section=003&model=2006-sbk999s
(29 & 30)
Regarding the orientation: https://www.ducati.ms/forums/722222-post8.html
So this side should point to the inside of the engine (I presume):
We will need specifics before we can help. Bike? Pushrod? Seal location?
These Ducatis are belt drive dual overhead cam engines with a single push rod that belongs to the world of clutch. And in that clutch world there are no needle bearings or seals. There are o-rings.
Not being a jerk. Please be more specific.
I'll take that correction.Well at least the 999 has a needle bearing and a seal on the pushrod...
