Guys... I wonder, does the push rod suppose to turn along with the pressure plate? I mean, the push rod is connected to the bearing on the pressure plate, and I think the original intend was keep the pressure plate rotate without rotating the push rod (and the rod basically just push the pressure plate). The problem that I have now is:
- The rod will turn with the plate at N. Depend on the engine speed, sometime the push rod will turn with the PP, sometime it doesn't.
- I found oil on the other end of the rod when I pull the rod out. And my clutch is not exactly "dry" either. It is very dry of the first few plates - and some oil at the bottom (inner) pieces. I don't know where the oil coming from - possibly from the slave. Is it a common problem? Or is it a problem at all?
The bike is in fact running fine - I just worry that the turning rod will have negative effect on the 2 bubble seal at the inner end of the rod.... do I need a new bearing at the pressure plate? The old one still work fine...
Any input is welcome!
