Sorry I should have mentioned the Multi
would replace the Fjr. I’m getting too old for a 600lb motorcycle….😝
I mean the V4S isn't far off of 600lbs, somewhere between 540-570lbs. The early 1200s would certainly be the lightest.Sorry I should have mentioned the Multi
Zack Courts at Revzilla weighed his V4S press bike at 570lbs wet with no bags. The 1200's are lighter than that, its been debated but they are under 500lbs. My 13' 1200s with no bags, no center stand and a lithium battery is around 465lbs.Correct- I did see 536lbs laden. The 1200‘s are a few pounds lighter around 520 I think.
I don't think the FJR broke 600 lbs (dry) until the 3rd generation (2013?). It carries it's weight lower than the Multi's but the Multi's wider bars (leverage) and geometry make it more nimble at speed. Still. the FJR is the most nimble parking-lot-speed bike I've had.Sorry I should have mentioned the Multi
This is correct. In my opinion the V4 is more touring oriented than the 1200’s. I have owned a 1200 for ten years and rode a V4S 1600 miles in Italy and Austria. I definitely felt the weight of the V4 and it was noticeably less nimble than my ‘13.I mean the V4S isn't far off of 600lbs, somewhere between 540-570lbs. The early 1200s would certainly be the lightest.
Now the local weather is warming up and the winter detritus/salt layer is being washed off the roads I’ve re-started exploring lean angles on my V4S (still on scorp 2 tyres) & noticed I have more side tread left (unused) on the front than the rear as I seek to reduce the winter’s chicken strip widths. Just waiting on my spare wheels to come back from powder coating & new Dunlop Sportsmart TT rubber for the looming spring summer so will get a chance to test if these alter/improve sportiness of the V4 mutley. Ps it’s an almost new for new comparison between Scorps & TTs as the spares came with new Scorps so the became my winters & my original wheels/tyres the spare set, & my original rear wheel bearings we’re toasted so easier to sacrifice to the bearing puller prior to powder coating.Do any of you V4S owners who have fitted street rubber only wish you had 17” front with standard width tires or is it insignificant? I get if you’re pushing pace with higher lean angles you may have more confidence in a larger contact patch. But for moderate spirited riding I would think as long as you had decent tires you should be fine.
Wow this is very different from my impression. The engine braking on my V4S feels massive to me compared to my Daytona 675 or KTM 790 Adventure R. I don't have any experience of previous Multis to compare it to though.Also, engine breaking feels like you are riding a 2 stroke, need a lot of rear brake to compensate.
I can do tall and light; or short and heavy. I loved my Multi, but it was tall and heavy. I don't think a Multi is your answer.Sorry I should have mentioned the Multi
well, just my perception, compared with my 1260S or former 1200S (not even mentioning the pure engine breaking of my monster 1100 evo, for which I never use the rear brake).Wow this is very different from my impression. The engine braking on my V4S feels massive to me compared to my Daytona 675 or KTM 790 Adventure R. I don't have any experience of previous Multis to compare it to though.
