1 - 20 of 108 Posts
· Registered
Hi - I am a bit of a newbie here, but I thought I should take the time to post some details of a project I am working on at the moment. Some links have been posted before to the mototek forums
( http://www.mototek.com/forum.htm) , but I thought it would be nice to get some focused suggestions / feedback and interest on this forum.
Basically the aim is to take a stock 2003 999S and turn it into the ultimate street machine. I have been working on this project for about 8 months, and have been mainly accumulating rare parts from various corners of the earth !
· Registered
Discussion Starter · #10 ·
Bucci High Compression Pistons are structurally designed to reduce fatigue while allowing perfect oil cooling to occur from within the oil jets. In addition, this design incorporates a high flow dome and larger valve pockets for optimal tuning and thermal efficiency.
· Registered
Discussion Starter · #12 ·
Silicone coolent hoses, save a little weight and are tested to maintain pressures above 350 PSI (4-times the burst pressure of most OEM radiator hoses) and can sustain temperatures above 350° F.
Not that we will be pushing that envelope ...
1 - 20 of 108 Posts
