Hey guys, can someone please tell the the correct procedure to activate a new/replacement key and eliminate this error (2010 1098 Streetfighter)?
I’m trying to program a replacement key I just bought. the new key is cut correctly and was coded to match the code on the red card that came with my bike. When I try to start the bike with the key the bike wont start. What happens is; the check engine light (yellow) is on when I turn the ignition on with the new key (it is NOT on when I use my original key), and the bike won’t even crank when using the new key (with the original key it cranks and starts fine).
The key supplier (Ducati Parts Unlimited) tells me that this problem is because I need to synch the new key with the bike, using the factory manual instructions. Problem is, there are no instructions in the electronic manual or the owners manual that came with the bike. Also, I've googled and searched and all I found was the correct procedure for a 1098 Superbike, which I tried but doesn’t; work with my 1098 Streefighter: https://youtu.be/x88RGWqA4JA
Help please - what is the correct procedure for our bikes?
Note: Apparently the procedure I need to follow will;
- Wipe out the memory, in the bike, of the 2 keys that were previously active for the bike.
- Then It will learn the identity of the two keys that I now have, and then both keys will be able to start the bike.
