Hi There,
newly here in form so if I am missing something in my explanation please cut me some slack :wink2:
I have been running in circle trying to fix a "no pressure" in the lever of the clutch of my Ducati Monster 1200s 2015. I was able to fix the "pressure" issues by bleeding the pocket of air that was in my master pump. In my ignorance I thought the issue was in the slave pump (actuator) which I didn't have to replace, but I did. In addition, In my wrong thinking I thought the issue could have been with something that got loose in the (wet) clutch case. Her's my problem, after draining the oil and removing all 10 bolts I have been unable to open the clutch cover. I used a mallet to see if it would help, but with no luck. I think the cover is sealed with liquid gasket and that is making it difficult to open (??). I have seen several video on youtube how relatively easy it is to open the cover, but it's not in my case.
I hope have attached correctly the video and it will help understand the issue. I would be very grateful if anybody has any suggestion to remove the cover. Thank you in advance for your precious time and reply!
Best,
JP998
Best,
JP998
