Problem with my Monster’s generator I think
992 7
  1. So I was enjoying my motocycle after a long time (hip replacement both)when one day went to turn it on and some sort of relay sound downstairs clicked and no cigar! Had it taken to my shop where they found it was th starter an replaced it... THEN it started behaving like out of time as if a problem with the injectors But no. The injectors are fine. while dealing with it the battery went dead, and since they’ve kept on looking and the latest report is that once the motor warms up after half an hour the battery dies again. The mechanic thinks it could be de generator, is there a way of finding out if it is? Or will I have to buy a new one and hope for the best? Nope no scanner in the shop?
1 - 8 of 8 Posts
Mechanic should have tested the charging system and load tested the battery before replacing a starter. Wires to the regulator and to grounds should be checked, and -- you don't have a generator, you have an alternator.
troll account?
That is a scary shop you are taking your bike to ! They can’t even check alternator output ? They are guessing as to what might be wrong ? Find yourself a decent motorcycle shop, even if you need to drive 100 miles. These guys will cost you money and screw up your bike. They are guessing at your expense. Where do you live ? Maybe someone can recommend a reputable mechanic in your area.
A standalone stator output test...if ok, follow with an RR test. Inspect all wiring and connectors between, all frame ground points too (clean) ......the logical diagnostic path in a suspected "not charging" situation.
Discussion Starter · #7 ·
Thank you soooo much.., dorsn’t get anymore specific
Yep will d
  1. Ya
  2. That is a scary shop you are taking your bike to ! They can’t even check alternator output ? They are guessing as to what might be wrong ? Find yourself a decent motorcycle shop, even if you need to drive 100 miles. These guys will cost you money and screw up your bike. They are guessing at your expense. Where do you live ? Maybe someone can recommend a reputable mechanic in your area.
    San Juan Puerto Rico
Don’t you have any motorcycle dealers that have trained mechanics for any brand ? Whether Ducati or other, a factory trained mechanic at least received basic electrical system training. They could diagnose your motorcycle properly.
1 - 8 of 8 Posts
