So I always wondered why people were having trouble getting Pro Taper Henry/Reed bars to fit on their HM's, when they worked perfectly fine on mine...
Well, I figured it out!
Apparently, somewhere along the line, Pro Taper changed the design of the bar! While the key specs are presumably the same - width, rise, and pullback - what they changed was the length of the taper from the fat part of the bar to the skinny part.
On a newer bar I was looking at, the taper is stretched out longer than on my bar, which makes the length of the straight part shorter. My bar has 8-1/2" of straight bar before it bends, while the new one has only about 7-3/4" of straight.
No wonder they don't work!
For reference, I checked a Carmichael bar, and while it's a little bit lower than the Henry/Reed, it appears to have enough of the straight bar to fit all the controls.
I don't know which of the other Pro Taper bars will work, and which ones won't, and there's really no way to tell without physically measuring a bar in person. They don't list the pertinent spec in the charts.
There's another good reason to shop locally, instead of online!
So anyway, mystery solved...
