This is a great kit for your dry clutch Ducati. This Kit includes a Motowheels billet pressure plate with aluminum spring retainers and a new throw out bearing, Polished stainless steel springs and an aluminum clutch cover. On sale for $259 while supply lasts.
Details on the parts included:
MW Billet Clutch Pressure Plate:
Add some style under a vented clutch cover with a Motowheels lightweight billet aluminum clutch pressure plate in anodized red. It also includes aluminum spring retainer cups in various colors (Please specify-silver,red,blue,gold,black.) and a new throw out bearing.
Polished SS Clutch Springs :
Eliminate the unsightly, rusted and worn out OEM springs with a new set of highly polished Motowheels stainless steel clutch springs.These springs have a slightly heavier spring rate for a better clutch engagement.
MD Aluminum Clutch Cover:
Die-Cast Injected Aluminum and CNC machined for accurate fit and design. They are lightweight and will fit most Ducati's with a dry clutch. This product is Made In USA . There are 8 styles of clutch covers, available in Black only
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=442%7CDucati%20Clutch%3A&productID=4498&showDetail=1&categoryID=742|Clutch%20Kits&vendoridtodisplay=0&filterFor=&collection=168%7CEuropean%20Motorcycle%20Parts
Moto, I'm not sure if this is the right forum for this question, but I figured I'm a multiple time customer of yours, so I'll ask it in your forum.
I just got my SpeedyMotor ARUN clutch cover today and installed it a few minutes ago. Looks (and sounds) great. Just wanted to be sure, but 2 of the bolts don't even make contact with the cover. Is that a typical install? The cover is only secured by 4 of the 6 bolts?
*Dan
*Dan
seems like it is typical of alot of clutch covers!....I'd still snug those 2 remaining bolts into place to help keep the clutch side engine casing from leaking and other possible weird effects!
Administrator
*Dan
Yes, this is normal.
Tighten them down, with a little loctite in place.
That way they don't back out.
All of us that have done this mod, have the same thing.
Not a big deal at all, as long as they are snug.
Sounds good to me. Thanks for the quick replies, guys.
Now it's time to get back to the search to find me a better tail and signal light option.
*Dan
