Anyone using PCV with AutoTune? If so, what is your set up (slip ons, ProTune, etc.) and what are your results?
I understand that it needs to be used with something such as the ProTune reflash, that's why I'm asking about set up, maybe I needed to be a little clearer on that point...You do understand that it won't tune anything in the closed loop operation range, right?
That's why none of us are running out to get these things.
To take full advantage of a Power Commander III or V installation. Otherwise you cannot tune below 19% throttle or 5250rpm. Here is a quote from Bucknut, a slight threadjack on a Protune thread...first you need a DP ECU that usually comes with the termis (right?) and then you can add the PCV with autotune and you can change the closed loop operation range...if i am wrong pls correct me people...
Here's the problem CTS - the pc will not adjust any settings while in closed loop operation. traditionally a DP ECU would completely eliminate any closed loop operation but the new DP ECU's (all09 and later models) seem to now operate in the same manner as the stock ECU with a portion of the rpm range in closed loop.first you need a DP ECU that usually comes with the termis (right?) and then you can add the PCV with autotune and you can change the closed loop operation range...if i am wrong pls correct me people...
Hi all. I've been haunting this forum silently for some time trying to absorb all the great info you all have to offer about the 'Fighter.Here's the problem CTS - the pc will not adjust any settings while in closed loop operation. traditionally a DP ECU would completely eliminate any closed loop operation but the new DP ECU's (all09 and later models) seem to now operate in the same manner as the stock ECU with a portion of the rpm range in closed loop.
For these later bikes I've not read anything that tells me if the PCV will work in the lower RPM ranges even with a DP ECU.
Therefore a protune, tuneboy, or custom reflash seems like the best option at this point
Jones, it seems that you are missing some information, the New ECU's use the 02 sensors and do operate in a closed loop mode as do the stock ECUs. There is no 02 eliminator available as of yet. (but I believe dynojet has a prototype).
For these new bikes a DP ECU and PCV will not solve our problems.
I have no doubt that the PCV will solve my issues and work for me as well as it worked for you. The big difference between your Kaw and my Ducati is that there are two ECU's available. The stock one is not tunable in the areas of concern (Unlike your stock ECU) and the Ducati Performance ECU is required to achieve results like yours. Thanks again for your input, I look forward to your results on my bike!I've been using a PC V with Autotune all summer on a Kaw Versys, so I have a bit of experience with them. The Kaw originally has no O2 sensor, so is open loop. I installed a fuel map for the closest setup to what I have (Leo Vince), and the Autotune reads the A/F ratio and alters that fuel map. Its range is restricted to 20% + or -, so after running for awhile, I plug the laptop in and pull up the offset table and accept the offsets. This incorporates them into the map and then zeros out the offset table. After doing this a few times, the offsets become less and less as the map approaches the ideal setup. The point I'm trying to make here is that the Autotune effectively converts the system to a type of closed loop operation and would do the same with the stock Ducati ECU, even in the lower RPM range. The PC V alone without the Autotune would not do this. I've had good success with it, and all of the fueling problems associated with the stock setup are now gone.
The PC V with Autotune bypasses the ECU. It ties in between the main harness and injectors and modifies the pulse width to correct the A/F ratio. The DP ECU doesn't know that the PC is doing this because it has no O2 sensor input. The Euro Versys is closed loop with an O2 sensor, and Dynojet makes a sensor eliminator that plugs into the original harness connector and fools the ECU into thinking it's still connected. I see no reason that the same thing wouldn't work on a stock Duc ECU.I have no doubt that the PCV will solve my issues and work for me as well as it worked for you. The big difference between your Kaw and my Ducati is that there are two ECU's available. The stock one is not tunable in the areas of concern (Unlike your stock ECU) and the Ducati Performance ECU is required to achieve results like yours. Thanks again for your input, I look forward to your results on my bike!
I'm sorry that is not correct.The PC V with Autotune bypasses the ECU. It ties in between the main harness and injectors and modifies the pulse width to correct the A/F ratio. The DP ECU doesn't know that the PC is doing this because it has no O2 sensor input. The Euro Versys is closed loop with an O2 sensor, and Dynojet makes a sensor eliminator that plugs into the original harness connector and fools the ECU into thinking it's still connected. I see no reason that the same thing wouldn't work on a stock Duc ECU.
Well, one reason would be that the PC website states that a DP ECU is required...that's good enough for me...I see no reason that the same thing wouldn't work on a stock Duc ECU.
Look, I don't know the answer but why would the o2 sensors need to be installed in a system that doesn't use them - a system with it's own ECU? Just to shut off a CEL?I have something to add that may help you out here.
A friend did get a full termi system with the DP ecu. The bike does run open loop BUT the sensors must be kept installed to the bike. If they are disconnected ther "check engine" light stays always ON.
My friend has the O2 sensors removed and has the check engine light always on, he doesnt mind...the thing is the bike works OK (proof its on an open loop mode) and he says that it runs very smoothly and cant be compared with stock bike settings...
so i think that with a DP ECU and a PC we can make a perfect map...
The reason why we're still having this discussion, is that the SF is very new, and nobody has bought a PC V for one yet. If you have a SF and you're in SoCal, I can get you in touch with best tuner out here in the west. Now, if you're far away or at altitude and don't know of a good tuner, than go ahead and pick up the AutoTune option (which allows your bike to be automatically tuned and maped as you ride).
If a tuner has installed a pc with a 2010 model bike and a DP ECU and can tell me for sure
if those function have been resolved I'd like to hear about it.
I'm with Flyn on this one. I have the Termi slip-ons which come with the DP ECU and I also have the PCV installed, sans Autotune. Tuner created a custom map and I still have the 3500 rpm fueling issues. Tuner says he can't tune in that range... Tuner's been creating maps for over a decade. Just saw him create a map for a K1200 with a PCIII. The owner downloaded a map for his bike and it wasn't running smoothly. Bike gained 9 rwhp and is now much smoother.The point I'm trying to make here is that the Autotune effectively converts the system to a type of closed loop operation and would do the same with the stock Ducati ECU, even in the lower RPM range. The PC V alone without the Autotune would not do this. I've had good success with it, and all of the fueling problems associated with the stock setup are now gone.
