I just checked and the Dyno Jet website is updated with a product # now instead of the "coming soon" that was there a few weeks ago. That good news!Well I don't know what he's thinking but the PCV has been out for a couple of months now...
http://www.shop.kyleusa.com/product.sc?productId=383&categoryId=134
What you can't yet get is the "o2 eliminator" that will allow it to work with our bikes...
NOPE! read the description under the PCV on Dynojets websiteI thought the O2 eliminator was part of the PCV???
Ok, I just called Dyno Jet myself to see whats what. This is the deal. The PCV does override the closed loop system and eliminates the O2 sensors. You don't need anything else to tune it, it works with the stock ECU. Thats the good part. The bad part is, that's how its designed to work. He said they are not shipping them out as of now because DynoJet has not been able to figure out how to override the O2 sensors on all the new Ducati's, Moto Guzzi's and Aprilia's. Maybe their are others but those are the ones they mentioned. They are working on it and he believes they will figure it out but no ETA. He said give him a call in a few months. Ugh.oh I see... you're waiting for a map for the SF supplied from dynojet.
Otherwise they are all the same, The connectors and the hardware are the same for 1098/1198/SF and a lot of other ducs.
A map can be created by your tuner and loaded into any existing PCIII/PCV. A custom map will always work better than the one supplied from Dynojet.
Doesn't matter, the PCV will not over-ride the closed loop system anyway (even with the factory supplied map). A PCV alone will not fix our bikes
The o2 eliminator is required to fix our bikes, after that - then a PCIII or PCV will work just fine.
Very interesting, I've been talking with Dan kyle about this issue since 07 with the 1098!Ok, I just called Dyno Jet myself to see whats what. This is the deal. The PCV does override the closed loop system and eliminates the O2 sensors. You don't need anything else to tune it, it works with the stock ECU. Thats the good part. The bad part is, that's how its designed to work. He said they are not shipping them out as of now because DynoJet has not been able to figure out how to override the O2 sensors on all the new Ducati's, Moto Guzzi's and Aprilia's. Maybe their are others but those are the ones they mentioned. They are working on it and he believes they will figure it out but no ETA. He said give him a call in a few months. Ugh.
The ProTune ECU remap kit is looking more inviting every day...all we need is for someone to try it and let us know if it works...But for now, as I said (and apparently dynojet confirms), the PCV will not fix our bikes
