Just E-mailed morepowerracing.com about the Power commander 5 for the 696. They replied that It will be released August 26! Too good to be true?
Probably...but my fingers are crossedreleased August 26! Too good to be true?
Unfortunately that's not the case with the 696 & 1100. The pair of O2 sensors and closed loop map are used on ALL of the Siemens ECUs. This includes stock, slip-on and full system ECUs. The only way a PCV will have full control of the entire map is if Dynojet is successful in the development in their O2 sensor eliminators. Their current version does not work with the Siemens ECU, but I believe they are working with a different type. I have a custom pair of O2 eliminators on my bike and so far it's running great with a new fueling module (http://www.ducati.ms/forums/showthread.php?t=69490).then the 1100 should be shortly after right? but it might be that it will not work below 19% throttle and 4,000 rpms unless you have the DP ECU
I believe he's saying that unless power commander comes out with a unit that can eliminate the stock O2 sensors, it will not work with ANY ECU, including the DP ECU.Thats confusing... What exactly does that mean? That it is not as simple as getting a PCV, having someone install it, and then getting it tuned?
Correct.I believe he's saying that unless power commander comes out with a unit that can eliminate the stock O2 sensors, it will not work with ANY ECU, including the DP ECU.
Exactly... not holding my breath at the moment.
It's been "available" and vendors have been taking orders, and money, since December of '08. I'll believe it when someone actually gets one installed and it works
