Power Commander 3 USB for the SC and PS for 06 and 07 "Graphs and Dyno"
here are the graphs on my PS. from stock to add on's to PCIII USB w/ coustom mapping. if anyone needs the map for the same set up as mine just pm me and i can get send you the map or tell you were i got my bike done at. the PCIII that you will need is part # 716-411 i got mine for $265
the 1st run is in blue. the bike was all stock with 1485mil on it.
the 2nd run is in brown with the DP ECU, Air box mod, BMC air filter and the 2 into 1 termi system.
the 3rd run is with all the add on's and a PCIII USB with coustom mapping, set at 13.0 to 1 air/fuel through out the map.
as you can see when the bike is at stock its torque dips at 3rpm and slowly comes back up to 6rpm were it tops off at. with the DP ECu it help it out alot, making it a nice curve. whit the power commander it made it much better, nice and smoth power ban and i've seen that the bike does not vibrate any more when im at low rpm, and opening it up to through out the higher rpm. with the PCIII it is like night and day.
just to let eveyone know you will need either a DP ECU (very expensive - appx. $1200.00) or a ECU from a pre '06' DS engined bike i.e. salvaged Multistrada, Supersport, much more economical. because the stock ECU from our SC/PS is a close loop system and the PCIII will not work with it.
If you have more questions just PM me.
the 1st pic is the BHP
the 2nd one is Troque
the 3rd one is HP, Torque, and Air/Fuel
the 4th pic is my PS
