1 - 9 of 9 Posts
I believe I'm missing the black rubber or plastic piece between the rear sprocket flange and rear wheel as shown in this photo:
I had the BMW dealer install new tires before I purchased the bike as it still had it's original 2002 date coded tires on it, I'm wondering if it got misplaced. It doesn't appear that Ducati sells it seperately according to this photo:
Does anyone know a source for it or have one laying around perhaps?
i have a feeling i have seen one of them at some point, but apart from that i can't recall ever seeing one fitted to anything i've had a rear wheel out of. is it off something really late model like a scrambler or 797 maybe?
I don't have one on mine. Never did.
Ok thanks! While cleaning my chain (after getting caught in the rain the other day... twice now on the Duc after going years without getting wet lol) I noticed that it appeared I had a tiny gap between the flange and the wheel, so I went to do some research and that photo showed up under a google image part number search on the flange. Looking at it again just now I realize that photo is of a newer Monster's part. It uses the same flange as our Sport Tourers but apparently the 2009 696 adds that rubber piece although it says " 71313501A SPACER (SARCHESINI ONLY)".
NOT oem on any ST series wheel , I worked at the dealer during the entire ST series time frame and there never was a part like that oem.
I have always had one in my 99 ST4 rear wheel.....it's a CUSH DRIVE. It's made from cast aluminum? surrounded by rubber and the pegs are steel screwed into the aluminum....see the indented hex heads? When installed into the wheel the pegs are hidden and only the outside of the drive barely shows and is hidden behind the sprocket. I have the stock 3 spoke wheels that were original on the bike.
‘07 ST3s
Glad that got settled .... was starting to worry mine and several other ST’s I’m familiar with were are inexplicably missing the same part .... duhhhh
1 - 9 of 9 Posts
