wasup guys, so i took my bike apart to powdercoat and now I'm putting it back together and when i tighten the wheel nut and sprocket carrier nut to torge i cant even spin the rear wheel.? can someone please help?
There's a few spacers back there: ensure you've assembled them correctly. Refer to the parts manual for the proper sequence...
well if they taped off any metal on metal surface or running surface then it shouldn't be that. but experience tells me when something goes wrong out of the blue look at the last thing you've changed.... check the manual for the right sequence of spacers like zetatre said, otherwise I'd start looking for a powdercoated surface that shouldn't be powdercoated...
