Have you done any work to the clutch system, i.e. fluid drain and fill or adjustments? You may also want to take a look at your adjustment, it may be backed out all the way. It sounds like your slave cylinder is fully engaged. This happened once on my 999, it took a little messin with but it finally went back to normal.
