Hi all, i have an issue with my Ducati Monster 620 2004. I was starting the bike up when i noticed it was extremely hard to get the bike to idle, i had to use choke and throttle in order for the bike to stay ”Alive” after 5-6 minutes on idle (felt like it was going on one cylinder) i was Dumb enough to drive the bike and it had No power at all and kept Dying at redlights etc. After the drive i tried to start it again the next day and i wont start. The Fuel pump sounds as usual and most likely gets fuel. The plugs were a bit black But still fine i think. I also charged the battery and it reads 12.5V. I have tried everything from changing the fuel to fresh one and checked connections and cables.. Please help with your advise and excuse my english
Did you remove the rats nest from the airbox yet?
seriously look for a reason it is rich which could be too much fuel (bad ecu) or simply not enough air( plugged airbox).
12. 5v on a charged battery is a little low so you may have a bad battery. Do a load test. Definitely make sure the air filter is clear. I always start diagnosing running issues with new spark plugs. Check to see if you’re getting a good spark.
