The play you refer to is usually normal to a extent.
The part is some times called a Cush Drive.
It cushions the drive line so on acceleration it feels smother and quieter.
I don't understand the other part of the question, but you should use grease to reassemble the axle internal parts so that it will not get corroded from the elements. A small coating is all that is needed.
