The little wrench came on this weekend. I was hoping it would last a few more hundreds of mile...
I'm pulling together everything I need to do my first ever service on a Duc: new belts for sure and at a minimum checking valve clearance. I'm still debating on whether do the MBP retainers now or later, so I figure I'll let clearances dictate my choice.
That said I was wondering if you guys use a piston stop to accurately set the degree wheel to TDC. The spark plug hole is deep and narrow so it looks like the longer piston stop from Motion Pro is a good idea albeit is 40 bucks. What about just using a 10mm Allen bolt? Is the marking on the drive pulley & case not precise enough?
Thanks!
Sent from my Nexus One
Thanks!
