Can someone please explain to me how to remove the factory pinch clamps?
I’ve never worked with these before.
salma hayek worth
Stick a thin blade screw driver in the first hole after the join and leverage the clamp open...then use a needle nose pliers to squeeze the clamp shut...with pressure into the clamp squeeze the pliers just after the lips that make the clamp connect and it will click snap together...the pliers will quickly close and draw into their jaws with great mysticism any nearby fleshy apendage....as you wince in pain you will be somewhat accepting as the clamp is now closed...apply cold beer
