1 - 16 of 16 Posts
No surrender
Nice pics !!!!
Mayor of Simpleton
Looks great.
amazing!!! usually dont like yellow to much but damn does that work. what front end are you running?
Discussion Starter · #10 ·
Thanks guys. It's a 1098s front end. Pretty straight forward swap. Just make sure you have all your parts before you do it.
I always say yellow needs more representation since it's not as loved as red. It's really just how you put it all together.
She is a beauty, although I'm partial to red on Duc I'm partial to yellow on anything else and I think Duc's look great in yellow as well. My 998 started out as a yellow (but previous owner changed her over to red). The front end does look nice...
Can you re-use the stock front wheel and brake rotors w/ the 1098S front end setup?
Bike looks great!
Super Senior Poster
Every time I see a yellow Duc I want to get my red 03' 999 repainted in yellow.
The 1098 front end looks right at home on the 998. How do you like the mono block calipers? I found them touchy at first on the 1098 that I rode for a short spin. I never got used to them....very, very powerful!
You have a exceptionally nice 998, looks complete w/ full Ohlins suspension:)
Discussion Starter · #15 ·
Yes and no. You certainly can reuse the front wheel as I have. You can not use the stock rotors or the 1098s rotors. You will need to get 15mm offset rotors which came stock with a 748R or a 998R. There are aftermarket companies that make rotor replacements for the 748R or 998R as well which are 15mm offset.
Thanks ZDM. Yellow is a nice change in an ocean of red sometimes. For the monoblocks, It wasn't hard to get use to. After bedding in the HH pads I got, they felt amazing. Just don't give it a hand full of squeeze and you're good lol. Gradual is key. :)
1 - 16 of 16 Posts
