Hi,
I have a Termi half system on my 04 999. I installed the DP ECU that came with the kit and then installed a PCIII and had a custom map developed on a dyno.
My questions are:
1. When I take the bike in for service, do I need to diconnect the PCIII for the Mathesis Computer to properly view data from the ECU?
2. Prior to the DP ECU and PCIII, I had adjusted the TPS and synchronized the throttle bodies to alleviate the stalling problem at idle. After the DP ECU and PCIII, the problem is back. Can I adjust the TPS without affecting the PCIII tuning?
Thanks in advance for your help.
My questions are:
