Front rim only $250
Front rotors $100
Rear rim forged aluminum rim is rough elongated holes $200 can be repaired
Pitbull stand $100
Air tubes $100
Full term exhaust from a 1098 custom welded to fit a 996 $250
Swing arm only no shock or hub $75
Rear hub $175
AFAM QUICK change sprocket $75
Showa shock 748-998 $75
2 sets 4 pad calipers gold or silver $250 each set
Gauges $175
2 triple clamp lowers 53 mm $250 each
998 oil cooler $125
996 oil cooler s125
Tank no dents, w/o pump or gas cap $250
848 rear show a shock s75
Fenders $20 each have red one not in picture
1,6 ecu with bff stage 2 chip$350
Full 996 wire harness $200
Two stock radiators one with 2 fans$150 & $250
Stock front calipers 2 set black or gold $75 each set
Sub frames gold & silver$50 each
Full 45mm 998 stock exhaust $100
2 frames 99 - 996 clean title, 98 - 916 clean title $300 eac
Pistal piston set $400 r2000 set 14.5:1
Custom made radiator for 996. Gsxr radiator custom welded to fit a748-998 $400 comes with modified hoses and fan
Red or yellow airbox $70 each
998 forks $300
748 forks need seals $100
Fuel pump assembly $250
Have other stuff as well.
Do not include shipping & packing
Gary 407 617 7496
Are the sub frames mono or bi?
they are bi-posto
1999 996 frame sold
