Hey RKGT- I use the Trackside stand (from Cycle Gear/ Revzilla). It works. Is it the best? No, the Pitbull is probably better, but it works. It does fit under the GT1000 swingarm- believe I have the rubber pads out as wide as they can go. I also wrapped the little "ears" in electrical tape to help reduce the chance of them scratching the swingarm if you don't get it lined up perfectly. If you get it, don't try to stick it too far forward, towards the center of the bike (that's when I scratched mine), but keep it further toward the back, like right under the axle. Believe that's what the Pitbull instructions show too. Someone, correct me if I'm wrong on this advice..
I do like the pads on the Ducati stand NCGT1000 has. Nice side support for positioning and keeping the bike from sliding to either side.
This discussion reminds me that I was going to build a support rod that would slip in the through the rear axle (I think I recall 5/8' stock would work) that I could attach spools on the end, and use the spool side of the stand, rather than resting on the rubber pads. I even already purchased the spools to use. Hmm, Now you got me thinking of yet another project to get to... Agh ! 😯
