1 - 2 of 2 Posts
Hi
Which oversizes connecting rod bearing exist for 1098 base model? Blue and yellow is standard (what size is that?) but after crankshaft/rod grind we need oversized spec.
Thanks
Sent from my Lenovo P2a42 using Tapatalk
you can get the 0.25 and 0.5mm undersize bearings from the older 2v catalogues, but they're so expensive that it pretty much makes crank grinding not worthwhile compared to an ebay s/h one.
1 - 2 of 2 Posts
