1 - 8 of 8 Posts
I think it varies -- not real accurate between bikes. The only way to really know for YOUR bike (but not necessarily trust 100%) is as soon as the light comes on, fill it up completely, calculate how much gas you had left by the amount you put in and figure your average MPG a few take fulls. Should get you close as long as you ride it the same way every time.
I've owned a '97 SS/SP, '96 SS/SP, '02 998, and (now) '02 998S Bayliss. Each one has the fuel warning light come on at 2.8 gal. used. As I recall the capacity on the SS/SP's was 4.1 gal. Not sure about the 998's but I thinks it's similar.
My light is on all the time. I got so tired of it that I stuck a piece of black duct tape over it. I fill up around 140 miles. I wish I could tell you how much I have left when the light 'goes' on. :mad:
Sounds like the float is stuck in the sender. You might be able to free it up by removing it, shaking it vertically -- possibly needing to spray some carb. cleaner inside the little holes. Might take more then once to accomplish....
If it’s the same unit as the 748-996, etc. They used a plastic nut that is prone to cracking ad causing a leak. As a shameless note :eek:: I do have replacement aluminum nuts available. Click on the link below to view.
1 - 8 of 8 Posts
