If you ever want to see the anatomy of the inside of your thumb, don't wear gloves, break free the 21mm oil screen bolt, and at top force send you hand into this little gem...
OMG!!! You win for sure...man I hope that's not you. That looks really painful. What happened?Hey it could be worse.... open belt covers
I nearly lost a fingertip to a BICYCLE chain. I'm still shocked at my own stupidity and I'm not going to try to explain how I managed to do it. My left pointer finger is permanently more pointy and mostly numb.we had an mv owner who would lube his chain with it on a rear stand, running and in gear. until his thumb went around the rear sprocket.
The result of complacency on my part around power tools. Gloves wouldn't have helped but the push stick that was within easy reach certainly would have. As with the hand through the chain/belt sprocket scenarios mentioned, stupidity is the start of many avoidable accidents.
At least there's a little Duc content.
I own a guitar shop in the Chicago suburbs. I used to play pretty good fingerstyle guitar before that joiner ate my fingertips. Be careful dude!Man you guys...Im a musician!
https://www.guitarworksltd.com/about/
