Had a chance to try out this clutch mod that some of the members have been raving about. Presently I'm running a Paulimoto basket w/ a Barnett clutch pack, FBF pressure plate, TPO springs w/ billet caps and titanium screws.
I removed the first of two metal disks that rest against the basket and replaced one w/ a used friction disk. Had trouble getting the tangs to fit the basket so I used a Dremel to round off the top of the tang and clean it up. This enabled each tang to fit tighter into each basket slot....lot of work, but perfect fit! Added the second metal disk, then a friction, metal and so on.
Replaced the pressure plate and springs, started it up......ah....all that tinging, metallic sound was gone....which was excaserbated by the Paulimoto basket. Can really hear the exhaust rumble now...and you can still hear a nice little clutch chatter...plus it seemed to smooth out the clutch engagement! Super easy modification that works well!
