Hey Everyone,
I think I erred in posting this to a sticky yesterday, as this is def a current issue :) Here's what I wrote then:
Hello Brad and thank you very much for making these videos. I'm adjusting the valves on my 1999 900SS following your method and I need some advice.
On my vertical cylinder I installed new openers and closers. At this point, when I measure the opener's clearance I get different readings depending on where the cam pulley is positioned. I also have the exhaust rocker pushed off to the side.
Can you - or someone following this thread - indicate where the dot on the cam wheel needs to be in order to get the proper measurement? I get different measurements depending on where in the free-movement arc I position the cam wheel [Edit: ... from either termination point of its travel].
Thanks!
991116
991117
991118
Just Visiting Your Planet
Turn the pulley with your hand and measure at its loosest point. That's where the rocker is off the lobe.
i do it on the base circle when the other rocker begins to move. so when the exhaust rocker starts to move, check the inlet there.
Thanks Yorik and Brad - appreciate it!
JK
