1 - 2 of 2 Posts
For those of you buying oil pails, what do you use for transfer?
I started looking at rotary or piston pumps to facilitate transfer in a gallon jug.
Then thought why not transfer from the drum to the bike direct? I tried a small submersible 12v pump I had used to move water previously, and the gpm is of course badly reduced pumping oil. Takes forever.
I then found some electric transfer pump but those are costly! There should be something between a manual 50-100$ pump and a 500-1000$ electric one?
I don't mind lifting the pail lid if it's a submersible pump. Would like a pump that could lift 5-10w40 oil a 6 feet column (pail on the floor and bike on a table) and flow maybe a quart every 10 seconds? Does anyone know how I can calculate the specs I need?
When I do something like that, I have a manual suction type pump I use . I bought it on Amazon. It’s ok to use for oil, or fuel if you clean it after. I use it to drain my gas tanks in the fall too. It really doesn’t take much effort.
1 - 2 of 2 Posts
