1 - 10 of 10 Posts
So i had a leak at the little oil seal at the end of the clutch push rod. That makes a lot of mess with an open clutch cover. Lots of greasy dust everywhere (and i mean EVERYWHERE).
The first 3 friction plates are soaked in oil, completely black. The 5 others look normal (more grey).
I have read some people saying the oiled plates are not good for use anymore ?
If i clean them with brake cleaner, sand them a bit, and grease with lithium ? Go or no go ?
You've had clutch trouble for a while, I say go with new plates and be done with it.
Clean the oily grit off with soap and water and reinstall. You realize that most motorcycle clutch plates run in an oil bath, right?
It's a newish pack so I would like to avoid that, therefore my question. Besides, I didn't had trouble for a while. It leaked maybe 2-3 rides before I catch it. It was just leaking a lot.
How many miles on the clutch ,, if over 15,000 change it if not clean ,lube ,install ,run it
Maybe 5k miles.
Absolutely. But I thought maybe the material was different? Some people experience clutch slippage when there's a leak oiling their clutch so I wondered.
Will clean and reinstall then
thanks
Clean them and use them if they’re thick enough. Most Ducati clutch friction materials are for use in wet or dry clutches.
Reactions: RockAZ
I use my clutch 20 times or more in the first 3 miles of every ride, .... I won't put up with a compromise on that component.
Discussion Starter · #8 ·
I never compromise anything on my bike, but that doesn't mean i want to throw a couple hundreds on it for no reason. Why fix what's not broke?
I cleaned everything, buttoned it back up, and it's working flawlessly like a brand new one.
That is not the way of the Ducatisti ! Every time the tiniest thing happens you are supposed to throw copious amounts of cash at the problem until you’ve covered it in carbon fiber and titanium. The mark of the truest of Ducatisti is the one with the least actual Ducati parts on their bike. Oh yes, no cutting corners either. Every aftermarket part must be really expensive and have the brand etched into it, otherwise, how will everyone know how much of an enthusiast you are ? It would be easier to buy a Harley. All you need is leather, chrome, and some of those tattoo sleeves.
Discussion Starter · #10 ·
All this while sipping an espresso in a ducati mug, watching the dealership tech doing it! :)
1 - 10 of 10 Posts
