1 - 12 of 12 Posts
When getting into the oil screen do I have to just un-nut the hex which I highlighted in red, do I need to remove the nut which is brass and connected to the temperature line (is it safe to remove this hex by the brass nut)?, and do I also have to remove the nut underneath which I highlighted also in red, or I don’t need to? Thanks.
Don't undo the plug at the bottom. Just use a socket on the large hexagon, leaving the brass hex in place.
And if it's the "first" time it has been removed be prepared to use all of your strength and a small elephant to remove it, and you will find a bit of stuff on the screen...it's to be expected.
Right. The "brass nut" should be left in the aluminium cap. It's actually the easily-broken hollow temperature bulb called the Thermistor. Torque value is a mere 7 ft/lbs (10 Nm)-- at most! See this thread from 2012: Oil Pickup Filter Hex Size?
To undo the filter screen behind the cap you'll need a 14mm allen socket. When I cleaned my screen at 36k kms as recommended, it was screwed in very tight. After I got it out I found very little in it --almost clean --though this might vary from bike to bike. I doubt I'll bother taking it out again at 72k kms unless the engine has had work done.
Can’t find my manual book, can anyone please tell me the correct torque spec for the oil screen, and the hex nut. Thanks again.
Would you check this when servicing a bike with 4k miles ?
Ducati recommend first cleaning of this filter at 36,000 kms in the Sport Classics. When I did mine (at 36k) it was so clean I wondered why I bothered --especially as I snapped the little brass oil temp bulb!
1 - 12 of 12 Posts
