You should check if it doesn't leak near the slave cylinder , mine 996 was leaking becouse of damaged left crancase cover silicon gasket , if it leaks from the gasket first try to torque the bolts properly becouse it could loosen . If it doesn't help you will have to take it off and re-silicon its surface
