749R leaks a drop or two a week. Seems to be coming from the three yellow wires coming out to the front of the Alternator enging casing. Any ideas? Is there a seal to repalce, or am I missing the leak from someplace else?
I have it in the basement to see if it leaks any further, but it may not unless it's been run, we'll see I guess.
If I drain the oil, can I pull the alternator side engine case off, and take a look inside, or is that a bad idea?
TIA
TIA
