Set out to tighten the leaking radiator hoses (annual Ducati winter leaks) and found oil weeping from the cooler.
Finally got it to the dealer. The connector to the cooler was loose. To tighten it, the line must be loosened first then tighten the connector.
The Engineer (Tell your mom hey)
last year, I had taken the covers off the lower part to access the hoses for some reason or another.. the water hose had been leaking in a similar location. I pushed the hose on more and tightened it down.. I should probably check it.
